Originally Posted By: 01rangerxl
Ouch.
You may be able to get away with cleaning up with a strong Shop Vac and small nozzle attachment, but I'd probably take the intake off so you can clean up debris more thoroughly and make the critical work of tapping easier to do. At least you will have a fresh intake gasket set on it too. Also, if you find you need to replace the intake itself, half the work will already be done.
Bummer.
Skip the nozzle attachments and tape an appropriately sized hose to the end of the shop vac. Then you can get down inside the hole and surgically remove debris.
Also if push comes to shove, Dorman makes a replacement manifold for this application.
