I do xOCI and UOA so we all might learn something.
As always, I'm happy with the results. Not much wear.
This oil info is about Amsoil ACD synthetic diesel 10-30w. The oil is 8 mths old, w/14,200 miles. The vehicle is a 07 Toyota FJ Cruiser w/a gasoline 4.0L engine that has 130.8k miles since new. I didn't dump/change anything when I took this sample. I always wait to see the UOA results. No make-up oil was added, because it doesn't use any. The vehicle is my daily driver. We live in the country, so it doesn't see much stop and go driving.
Many yrs ago I put a TopDog brand engine oil bypass filtration system on that utilizes the Amsoil EaBP90 filter. This filter was last changed 9/12, 46k miles ago. The air filter is an Amsoil EaA238(discontinued) element with 47k miles since new. Over the yrs, I've looked for induction system leaks and tried 3 different brand air filters elements in hope of reducing the Si/silicon level without success.
Now that I've seen these lastest results, I'm gonna change the oil, with what I'm not sure? I'm thinking maybe Mobil 1 or a conventional(dinasor) diesel oil like Shell Rotella T3, to see if they go 15k miles? I'm gonna change the full flow filter with another Fram XG8A. I'll install a new EaBP90 bypass filter element. I'll leave the air filter in place so as to NOT influence the next Si/silicon results.
LAB: Oil Analyzers Inc - OAI(Polaris)
LAB COMMENTS: Base # is SIGNIFICANTLY LOW. Abrasives (silicon/dirt) is at a MINOR LEVEL. Change oil filter, top off system, and re-sample in 3.5k miles or 65 hrs. Viscosity is SLIGHTLY HIGH.
Code:
WEAR METALS-PPM
Date 12/10.12/11.8/12.5/13.3/14.11/14
Iron 28....14....12....7....21...17
Chromium 0......0....0.....0....0....0
Copper 1......1....1.....0....1....0
Tin 0......1....0.....0....0....0
Lead 0......0....0.....0....0....0
Chrom 0......0....0.....0....0....0
Nickel 0......0....0.....0....0....0
Alum 5......6....7.....1....3....2
Silver 0......0....0.....0....0....0
Cadmium 0......0....0.....0....0....0
Vanadium 0......0....0.....1....0....0
CONTAMINANT METALS-PPM
Silicon 56.....70....43...32...33...37
Sodium 168....45....17...28...29...31
Potassium 4......2.....2....4....3....5
MULTI SOURCE METALS
Manganese 0......0....0....0.....0....0
Titan 0......0....0....0.....0....0
Molybdenum 2......0....0....0.....0....0
Antim 0......0....0....0.....0....0
Lithium 0......0....0....0.....0....0
Boron 6......4....3....1.....1....2
ADDITIVE METALS-PPM
Magnesium 14.....11....16....10....13....11
Calcium 3394..3531..4351..3589..3022..3520
Barium 0......0......0.....0.....0....0
Phosph 568...497....809...929...895..1037
Zinc 691...591....989..1130..1084..1236
V100C 10.9...10.8...12.7....14.3...15.2..12.7
I-R Oxidation 58......64.....61......25....67....50
I-R Nitra 39......41.....17.......9....18....18
TBN 2.66...2.18...2.48....2.35...1.89...2.22
Fuel
Soot Vol
Water Vol
Code:
WEAR METALS-PPM
MULTI SOURCE METALS
ADDITIVE METALS-PPM
Fuel
Soot Vol
Water Vol
