Probably a little late to the party and slightly off topic now, but I just want to make a comment on this post.
On the audio we have a discrete point on both tracks, which is when the lifter noise quiets down; this noise quiets down when one or more conditions are met inside the engine like oil flow or oil pressure, it really doesn't matter what makes the noise go away; what is important is that this noise only appears on a totally cold engine and that it is linked to the viscosity of the oil.
Now the noise lasts 4.652 s with the 15W-40 since startup and only last 1.825 seconds with the 5W-30. So we can say that the thicker oil took 2.5 times more to meet the conditions to prevent noise in the valve train.
Based on those facts we can extrapolate, and say that the thicker oil will always take 2.5 times more than the thicker oil to get to the engine components, allowing for 2.5 times more wear in every cold start.
This is just a first approximation but it leads us into the right direction, that thicker oils allow more startup wear than thinner oils.
This is the original post of that video.
