Originally Posted By: Clevy
Originally Posted By: Old Mustang Guy
I have an 01 Escape with 207k that leaks from the timing chain cover. HM oil helped some. My mechanic recommended putting some Lucas in it. Everyone here hates Lucas but it dropped the leakage way back.
Of course it did. You thickens the oil in a significant way. You thickened the oil and diluted that additive package. So you weakened the oil and worsened cold pumpability.
I'll go out on a limb here and say at 207k it really doesn't matter. While it may make 220, 250, 300k, who knows. It's certainly proved its worth.
Quote:
If you want thicker oil try a 50 grade. Because basically that's what you've got,except a 50 grade will have its additive package undiluted,unlike what's in your sump now.
The Duratec 3.0 holds 6 qts (at least the wife's 03 does). From what I've gathered, Lucas is a 60 weight oil and you replace 1 qt with it:
30+30+30+30+30+60 = 210 / 6 = 35
