Originally Posted By: CATERHAM
Being a thick oil guy I know you have expressed complete disdain for the 0W-20 grade and TGMO in particular but for those that are interested TGMO 0W-20 is pretty special:
Your statement big boy, now, as usual I will ask you to back your statements up...where have I expressed disdain against 0W20s, and particular TGMO
I admit disdain for the made up mythology that surrounds TGMO "the oil that we know most about", where "most is made up pixies riding unicorns spreading fairy dust...and that's where I call you out...made up "stuff" that you parade as science.
A higher VI (216-220) than all OTC oils.
There's the anticipated VI
A lower KV40 (36-37cSt) than all OTC oils.
There's that VI again...still counting 1 attribute
Higher AW additive levels than most 0W-20s.
Zn+Mo+B = 982 in Gokhan's VOA
http://www.pqiamerica.com/June 2014/consolidated 0W-20.html
5 out of the 7 have higher AW additives than Gokhan's VOA...some by a massive 16%...
hmmm, still sitting at 1 attribute
A proven high degree of shear stability, better than many much lower VI 0W-20s.
Fairly subjective as the ones that have shown shear you usually write off to fuel or other mechanical problem....and again, you qualified it with VI.
So I guess we are still stuck with one attribute not shared by OTC 0W20s...pretty much as I expected.
