I bought a Comfort Zone CZ220 electric heater for my garage. I have about 380ish square feet and this thing should keep it around 50* for me with relative ease. It has H/M/L setting that are 5,000, 4,000 and 3,000 watt settings that produce 11,000 BTU, 14,000 BTU and 17,000 BTU. It also has a built in thermostat.
It is mounted/hung and just waiting for my uncle to come wire it directly to the panel.
I had really wanted a blue flame heater but didn't want a ventless heater and the smallest vented heater I could find was 50,000 BTU and $500. This electric heater was only $200 but I also found it for $100 so I will be swapping it out. Plus, this electric heater is much, much smaller than a gas heater.
Local electric rates are $0.106 per kw/h. So, it shouldn't hurt to bad to run it.
Edit: forgot to mention, the garage is fully insulated including the door so it should work out half way decent.
