I canceled my order of the Amsoil SS and will stick with Mobil 1 for another couple OCIs and see if the oil stays cleaner longer as it breaks in. At least I flushed out a lot of the early break-in materials. Hopefully it will stay cleaner longer, but even if it doesn't the oil should still be good and oil color isn't an indicator of the condition of the oil. At least the oil is doing it's job. I went with a Fram Ultra oil filter on this OCI over the Amsoil oil filter. I have both on the shelf, so I may go to the bigger Amsoil EAO filter on the next OCI for more filtering capacity.
I also had the dealer change out my rear diff fluid under warranty to get all the break-in materials out of it as well.
