Originally Posted By: meborder
i dumped about a half bottle down across all 4 cylinders.
how long before you suppose all of that ends up in the crank case?
that is to say, when should i go out there and add some more?
can't find kroil anywhere, so i'm going to keep trying seafoam, MMO, and PBblaster/Penetrol 90 in the mean time.
It will take a while before it gets into the crankcase but it will get there sooner or later. To get a better soak after filling the cylinders try this: Crank the engine over if you can with a breaker bar. Or just tweak it with the starter every 8 hours or so. Then pour more of your favorite cleaner in, let is soak of 8 or so hours and repeat. I did one a while back and let Kreen sit for 48 hours, using the time table I mentioned above. Before you start the engine crank it over to get any excess product out of the cylinders before you put the plugs back in. Clean up the mess, start the car, warm it up and dump the oil and filter.
