Again, there really is no magic for 2 stroke oil ratio's.
32 to 1 provides all the protection possible, with the exception of very highly tuned race engines, such as 55HP, 125cc Kart engines.
50 to 1 is good enough for low stress engines. But, will result in slightly more wear for high performance engines.
100 to 1, regardless of oil type, results in significantly more wear.
Some oils that recommend lean ratio's, are either higher viscosity or contain no mixing agents or thinners (often a very small component of the oil, by percentage) . This does not mean you will achieve equal engine life at 100 to 1 with these "magic" oils. That "theory" has been soundly debunked.
And, 16 to 1 provides the most HP, jetting and other factors being equal. (8 to 1 may make a touch more power, but it's difficult to deal with)
