2004 Passat 2.8, 4MO, Auto
After a drain and fill i have the following situation:
Car is normal BUT lets say im a fast food drive up window or stopped at a long light when i take off i have a shift flare from gears 2-3 of about 50-100 RPM. The only time this happens is under those conditions, if the car sits in drive longer than 5 min or so the flare happens, well not the only now that i think of it, it did happen once when the car sat for 15 min park. Also, it DOES NOT happen if using tiptronic mode.
Everything else is normal. Only if im drive sitting for 5-10 min. Trans temp is 75-77c in these situations.
The only thing i have not done was change the filter.
Transmission is filled the right way, using VCDS, i have done this in the past with my A4 and its been running and driving great, im using MaxLife fluid. No errors or codes or anything.
I have been reading endless info about the transmission in this car and im losing my mind. Any one have anything like this? Could it be a clogged filter? Valve body? Tanny pump? Why only after the fluid drain and fill? All i do know its its very annoying. How long can it last? I wanted to get at least the winter before any crazy issues, would love to see 10k miles. But now im scared. The only change is that i did 2 drain and fills with maxlife...
I feel like maxlife is too thin and its some how draining out of the piston on 3rd, i was thinking of dropping the pan and putting a new filter in and filling her up with something else, M1 ATF or Pentosin ATF1
