Greetings, first time poster, long time lurker! I registered so I can get everyone's input on this UOA. The car is a 2008 Saturn Aura XR, which I picked up for my fiance in July 2014. We experienced on-going cylinder 4 misfires which the dealer was unable to properly diagnose, and has since "stonewalled" us when we requested compression and leak-down tests. I replaced the cylinder 4 ignition coil and spark plug with a new ACDelco coil and NGK iridium plug back in August. This helped but the issue persisted. After I went over everything again, including cleaning the throttle body, I noticed some oil in the cylinder 4 spark plug tube. This leads me to believe that the valve cover gasket and/or spark plug tube seal is leaking. I ordered the parts but have yet to replace the gaskets. After cleaning the oil off of the cylinder 4 spark plug, the misfire seems to have gone away.
Anyway, we were unable to figure out what kind of oil or filter the dealership used when they originally serviced the vehicle. My guess was a 5w30 oil as that is what is recommended for the 3.6 V6. According to Blackstone's testing, it looks like the dealer used a 5w20 instead. When I changed the oil, I used PP 5w30 and a Bosch D+. So far, so good, but I would love to hear what everyone else thinks about the UOA. I also included the comments from Blackstone's tech:
Code:
OIL UNKNOWN DEALER FILL
MILES IN USE 3,981
MILES 83,889
SAMPLE TAKEN 11/5/2014
ALUMINUM 13
CHROMIUM 1
IRON 13
COPPER 3
LEAD 0
TIN 0
MOLYBDENUM 23
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 70
SILICON 9
SODIUM 6
CALCIUM 2180
MAGNESIUM 12
PHOSPHORUS 700
ZINC 859
BARIUM 0
INSOLUBLES 0.2
WATER 0.0
FUEL %
ANTIFREEZE 0.0
FLASHPOINT ºF 395
SUS VIS 210ºF 52.4
cSt @ 212ºF 8.01
Thanks for the note. Most of the metals look ok.
A timing chain problem would likely show up as high iron, though
we've seen issues where a tension is bad and so the chain eats
into the aluminum housing. We do have aluminum here, but it could also
show piston wear or bearing wear in some engines. We'd lean towards the
aluminum maybe being from the misfire as opposed to a timing chain problem, but
it's hard to say. The viscosity is closer to 5W/20, but hat's fine. Run 4,000
miles and check back on aluminum. Hopefully it drops a little.
Code:
MILES IN USE 3,981
MILES 83,889
ALUMINUM 13
CHROMIUM 1
IRON 13
COPPER 3
LEAD 0
TIN 0
MOLYBDENUM 23
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 70
SILICON 9
SODIUM 6
CALCIUM 2180
MAGNESIUM 12
PHOSPHORUS 700
ZINC 859
BARIUM 0
INSOLUBLES 0.2
WATER 0.0
FUEL %
ANTIFREEZE 0.0
FLASHPOINT ºF 395
SUS VIS 210ºF 52.4
cSt @ 212ºF 8.01
