VC had to come off to install the updated timing chain tensioner. Also got new plugs, and a tune, which required more beating on it than the 11 months I have had it so far combined.
I couldn't get better pics, but it looked pretty good for the condition the rest of the car was in. I bought it at about 108K miles, did a few short changes with some MMO in the sump, and am about to hit 3000 miles on the walmart special oil. It's a 2.0 with a 6L sump, and synthetic 5-30 is called for for 5K miles I think. My thoughts are walmart special which is 5 qts of 5-30, and have them put in Rotella 5-40 for the sixth qt. VC will come off again and be replaced as I would like to be able to install the coil covers and injector covers, and the bolt holes have most of the bolts broken off inside.
Second from the right/bottom spark plug well had a plug loose when I pulled the plugs previously. I have checked them, and when we installed the new plugs there was no sign of stripped threads or a loose plug.
