Any one have a trick to keep the red spray tube inside the nozzle? I'm spraying my favorite rust prevention product - Rust Check, but if I bend that tube even slightly as I'm applying...that dang tube flies out! pppft and I've got the red foam all over my fingers!
Very annoying, especially when the tube flies into that small drain hole in the door and becomes part of the inner sanctum
Anyone have a solution ?
