Originally Posted By: Garak
With respect to sodium, did you ever have it serviced at the Nissan/Infiniti dealer? The Canadian ones use Mobil products as service fill, and if they used Mobil Super 1000 for you in the reasonably recent past, that could account for it, since that should be a sodium additive package.
OP mentioned the dealer used Mobil 1000 before driving it off the lot, so we know where the sodium came from.
A thicker, more shear resistant 30 weight might be in order. Does the manual allow for a 40 weight, if so M1 0w40 might be a good choice (It'll shear a point or two).
PU could be doing a lot of cleaning if the oil change history is unknown on this engine. Did you cut the oil filter open?
