There's more to harsh shifting than oils. Try cleaning, lubing and adjusting your CHAIN. This is where you get notchy shifts from.
1.Take charcoal lighter fluid and a red rag. Wipe the chain and sprockets down surgically.
2.Adjust chain slack per owners manual. Rotate wheel around and check for proper slack again.
3.Mix #2 grease and 80W90 gear oil. Apply to chain with a small brush. Rotate wheel for full coverage.
Better yet, remove the chain from your bike. Place in a metal can with some kerosene or diesel. Soak and brush it clean with a nylon brush. Reinstall and lube the snot out of it.
