This is the 3rd UOA for my 2014 GMC Sierra 1500 with the new 5.3 Ecotec3 V8. OLM was at 4%. Mostly highway driven (around 85%). Oil used was Mobil 1 0W-20 AFE. No make up oil was added and engine didn't appear to burn any. Filter was Fram Ultra XG10575. Previous two UOA's are with GM Dexos/AC Delco 0W-20.
I was hoping to see some of the wear levels decrease but not much changed. Iron is basically the same as the previous sample if you look at from a per mile basis. I can only assume copper is coming from the oil cooler.
TBN still looks strong. This is the first time I've done a TAN test. Would it be safe to say that 6.3 is about normal for this oil? I think we have confirmed that M1 0W-20 contains PAO and creates a high starting TAN?
As I have seen with most M1 0W-20 UOA's it does seem to have sheered a little. Still glad to see that fuel doesn't seem to be a problem with this DI engine.
