Hello,
Going to be using the Tahoe today, in our 1st storm. When exactly is the optimal time to be using the Autotrak function?
As I understand it, 4 wheel drive will automatically kick in/out, when needed. In conditions like today (6-12" expected), can you run all day with it on, without causing system issues? Knowing, roads aren't all that bad right now.
Alternatively, can you actually run 4 high in conditions that vary between snow covered and cleared?
I guess one thing I am driving at is this - how 'hard' is the Autotrak function on the drivetrain, in varying conditions; and is 4 hi ok under these same circumstances?
