This is a short-trip daily driver.
Last 1,000mi were in cool weather with 10-20F starts.
Car is a Versa Sedan with M/T.
I don't know if copper is oil cooler related or the crank thrust washer.
Refilled with 5w-30 G-OIL.
Input welcome.
Code:
[/code]
OIL Kendall
5w30
Semi-Synthetic
MILES IN USE 4,083
MILES 37,087
SAMPLE TAKEN 10/18/14
Metals (ppm)
IRON 6
CHROMIUM
LEAD
COPPER 15
TIN
ALUMINUM 7
NICKEL
SILVER
TITANIUM 85
VANADIUM
Contaminants (ppm)
SILICON 13
SODIUM 6
POTASSIUM
Additives (ppm)
MAGNESIUM 22
CALCIUM 2238
BARIUM
PHOSPHORUS 703
ZINC 814
MOLYBDENUM 93
BORON 156
Contaminants
WATER
Coolant No
Physical Tests
Visc (cSt 100C) 9.1
TBN (mgKOH/g) 5.1
Input welcome.
Code:
[/code]
OIL Kendall
5w30
Semi-Synthetic
MILES IN USE 4,083
MILES 37,087
Metals (ppm)
IRON 6
CHROMIUM
LEAD
COPPER 15
TIN
ALUMINUM 7
NICKEL
SILVER
TITANIUM 85
VANADIUM
Contaminants (ppm)
SILICON 13
SODIUM 6
POTASSIUM
Additives (ppm)
MAGNESIUM 22
CALCIUM 2238
BARIUM
PHOSPHORUS 703
ZINC 814
MOLYBDENUM 93
BORON 156
Contaminants
WATER
Coolant No
Physical Tests
Visc (cSt 100C) 9.1
TBN (mgKOH/g) 5.1
Code:
