I need to replace the clutch in my ECHO, I first bought a Sachs kit but it said "Made in China" on the box. I don't know if that meant everything or just parts, but the included release bearing was in a plain white box with no markings. I wanted to buy the Aisin kit but it said it was not for my early production ECHO, so I ended up buying a Toyota OEM clutch disk and pressure plate, and a Koyo bearing. The price was about the same anyway.
I'd suggest you look for an Aisin kit if there is one for your car. For me there was no way I was putting a Chinese release bearing in that car considering the amount of work required to replace it.
Having said that however - About four or five years ago I had to take the transmission out to replace the output shaft bearings as it was making a similar sound as you describe. It went away when the clutch was depressed, but if you let up on the clutch at a stop (with it out of gear) you could hear the noise. A machinist friend had to make up a couple of special tools to take off the 5th gears, and when we looked at the bearings it didn't seem obvious they were bad. But upon repair and re-installation the sound was gone.
Originally Posted By: BrandonVA
it really sounds like its coming from the clutch. i think i'm going to get a new clutch kit installed. dealer won't warranty it as nothing is broken.
now for clutch kits....luk or sachs?
