Driving back inherited vehicles from something semi recent I nearly ran one almost totally out of coolant without realizing it. (too depressed, sad, unfocused to figure out the problem before i'd put on 1500 miles) It's an early 2000's ford vulcan duratec v6 and it had almost no heat (was very intermittent) and was running hot the whole way. Spent alot of time at the top of the white (no dang temperature figures just L and H) and near end of trip went to the actual red on a few times - no steam ever came out, but it could well have been steam internally that didn't vent if it was too low.
When I realized there was no coolant in the overflow tank i poured in a GALLON of distilled water before it even had water stay in there (which still wasnt enough/below cold levels while hot) and then tried to top off with about half a gallon of 'universal' antifreeze - not sure if it's even up now just was too dark to see and too tired to care by that point. (I could not tell which color antifreeze was appropriate, hoped it'd mix with the distilled in the overflow tank after a few miles but didn't)
The added water and antifreeze stopped all lack of heat and overheating problems, car runs fine. Except for some obvious questions now:
- What did overheating the engine possibly screw up, what should I watch for or test when I finally get a chance (things will mostly be parked until spring when I hope to look at what all I have)
- Will the possibly 'wrong' antifreeze (ford cautions against any antifreeze but their own) screw up anything mostly sitting there and not seeing much driving. (may need it for some driving but cant get around to flushes or anything until spring)
- Since I don't even know how much was still in the vehicle (i'd assume if I put in 1.5 gallons not much!) and I didn't pour in premix, but first water and then pure antifreeze, any suggestions on how to correct or test mixtures to not freeze and destroy everything before spring. One internet posting somewhere suggested I shouldn't pour straight antifreeze into the overflow tank yet I clearly have too much water now.
