My daughter drives a beat-up 2003 Hyundai Elantra. She came to me with a bunch of codes showing, and the one I saw that I figured I could fix was for the knock sensor. So she ordered one from Rock Auto, and I looked up some info on replacing it. According to everything I read, it's on "the front of the engine." Since this is a transverse engine, I wasn't sure if they meant the side of the engine next to the radiator, or the actual front of the engine where the accessory belts are. I found a picture that showed it close to the A/C compressor. However, no matter how many times I looked, it wasn't there.
I finally figured out that it's located on the side of the block next to the firewall. Under the intake manifold, so you can't get to it from the top. We rolled it up on the ramps, and I could see it there, but there are a couple of engine braces in the way. Fortunately, I was finally able to come up with a combination of socket extensions that allowed me to take the bolt out. Due to the configuration of the braces and whatnot, putting the new one on was a bit of a chore.
So they managed to take a job that could be five minutes, and turn it into an hour. There's an oil leak somewhere on the engine too, so when I was done, I was a grimy mess. Fortunately the car runs better.
