Post your brake job pics!
Oahu, Hawaii
Since brakes are highly discussed as much as oil post your brake jobs here!
2001 Toyota Tundra. Power slot rotors (2nd time resurfaced) and Wagner TQ pads. Old pads were NAPA Adaptive One that lasted 4 years about 40,000mi.
Im surprised they cut them for you. Usually they wont bc it breaks the bit or ruins the chamfering on the slots
awww man, I just did a brake job for a friend of mine and she had ran the pads down to bare metal, which quickly ruined one of the front rotors. It was an amazing sight but I trashed the old pads and rotors yesterday without thinking twice. Wish I would have taken some pics.
Will post pictures of my personal cars a bit later when I rotate the tires.
Is that a right side slotted rotor installed on the left side or have I been drinking too much?
Sometimes it doesnt matter, Im sure Powerslot mentions something. I know on Mercedes with sport package and drilled/slotted (drilled in same way as slots) rotors, they send 2 of the same rotors, so mercedes doesnt care which way they spin
And on another note, a friend brought his Mini by today bc of a grinding noise from the rear. Turns out he put the pad in backwards. Just one pad, and he did all 4. Amazing.
Look at the direction of the exhaust header, its the right side.
The steering rack and sway bar are on backwards.
This is on the Focus. Old rotor that could not be turned.
New rotor from O'Reilly's.
This is the first time the brakes have bee replaced on this car, 108K+ ain't half bad.
This is on the '09 Fusion with 28 or 29k miles. Reason for replacement was vibration while braking that worsened as the brakes heated up.
Chunks missing out of the pad.
Raybestos Advanced gripped by Bendix CT3
After a StopTech Burn in.
2002 Chevy Silverado rear brakes. The NAPA Blue brake pads were dusting like crazy after a year after doing the rear with new rotors and upgraded rear calipers so I decided to get the rotors cut and install Wagner TQ's.
