Few questions first:
What is the present voltage of the batteries?
Does your charger indicate any current output when you connect it up?
An easy test to see if the charger is doing anything is to measure the voltage of the battery, then connect the charger and measure the voltage to see if it's higher with the charger connected.
One way to test the battery would require first charge up the battery (if it'll take a charge), then get it load tested to see if it can put out the current you need. If you can't get it to stay above 12V, it's probably toast.
No sparks could indicate that the charger isn't working.
Depending on the state of the battery, I think that trying to jump start the car could be dangerous, personally, I would swap the battery from a good car or use a jump box.
