With the tab modification, will they work in this car?
Also, if so, what is the equivalent Philips for the high beams that would also fit the '05 Corolla? Is it the 9011? Does that also require the mod?
(Deer are on the move and are original OEM's are now like holding a small flashlight out the window....even with freshly prepped lenses.)
Finally, if these are the correct bulbs and I like them, will they fit the other Toyotas in my signature?
