Here's the data from my third oil change. I used PUP 5w20. So far I have not ever had to top off the oil.
Html:
OIL MC5w20 ff PUP 5w20 PUP 5w20 UNIV AV
MILES IN USE 6,952 7,415 9,853
MILES 6,952 14,367 24,220
SAMPLE TAKEN 6/1/14 9/15/14 2/1/15
ALUMINUM 11 7 5 6
CHROMIUM 0 0 0 0
IRON 25 14 12 15
COPPER 47 9 3 2
LEAD 0 1 0 2
TIN 0 0 0 1
MOLYBDENUM 26 48 57 94
NICKEL 0 0 0 0
MANGANESE 21 5 3 1
SILVER 0 0 0 0
TITANIUM 0 2 2 0
POTASSIUM 4 0 3 4
BORON 4 52 53 76
SILICON 82 24 17 8
SODIUM 2 4 4 19
CALCIUM 1914 2284 2396 2467
MAGNESIUM 12 32 33 127
PHOSPHORUS 782 715 715 632
ZINC 914 798 841 708
BARIUM 1 0 0 1
SUS VIS @ 210ºF 52.0 51.1 51.8
cSt VIS @ 100ºC 7.88 7.62 7.81
FLASHPOINT ºF 420 405 400
FUEL %
ANTIFREEZE % 0.0 0.0 0.0
WATER % 0.0 0.0 0.0
INSOLUBLES % 0.1 0.2 0.2
TBN 4.0 6.5 4.7
Blackstone comments:
6/1/14
When it comes to the first sample, it's not unusual to find some higher metals and silicon. The metals are from new parts wearing in and getting acquainted with one another and the silicon is from sand casted parts and harmless sealers used to put the engine together. It might take a few oil changes to wash this stuff out, but eventually, your samples should look better than universal averages, which are under construction since these are new engines and we haven't seen many samples from them yet. The TBN was strong at 4.0 so try 8K miles next time.
9/15/14
There's a lot of nice progress to talk about in this sample. Copper has improved, and other metals have come
down a bit as well. Copper is still just high enough to mark, but another improvement like this next time should bring it
right down in range. Silicon might take another oil change or two to get there, but the progress is appropriate so far. The
TBN read 6.5, showing lots of active additive left in the oil. No fuel, moisture, or coolant was found. We guessed by
"5W/20 PUP" you meant Pennzoil Ultra, but let us know if that's not right. Nice progress!
2/1/15
The new 1.0L turbo engine in your Fiesta is coming along very nicely.
Wear metals have all improved. They are low and well balanced, showing that the engine made its way through the
wear-in process just fine. This is also a good sign that no mechanical problems are developing. The oil itself was free of
fuel and coolant contamination, and the viscosity was normal for a 5W/20. Low insolubles and silicon show good oil and
air filtration. The TBN came in strong, so feel free to try 12,000 miles on the next oil.
