Originally Posted By: wag123
If anybody who has been using MoS2 in their under warranty car suspects that they have an internal engine mechanical problem, just change the oil and filter before taking the car to the dealer for repairs. Problem solved.
Not really.
Mos2 sticks around because over time it works itself into the metals irregularities and it'll take more than an oil change to clean it all out.
And trav's point he made in the last mos2 thread popped up for me when I changed the oil in my C3.
When I got the truck it was neglected. So I did a few oil changes using an engine flush type product and cleaned it out,then I used redline for roughly 6500 miles.
I also added roughly a can and a half of mos2.
When I pulled the oil drain plug there was literally black thick mud on it. Enough to completely cover the magnet.
Which to me lends a lot of clout to what Trav has posted about mos2 in his boosted 3.8.
My truck is daily driven and still there was accumulation on the bottom of the pan.
So he's right about it settling out. It's my fault for overdosing for sure,so following the directions is key.
I like mos2. Every engine I've used it in gets better mileage and I will continue to use it. I just wanted to state my observations about potential settling out,especially if the engine isn't daily driven.
So Trav is right,and I believe him 100% now even though at first I was skeptical.
Now I'm not saying that mud in the bottom of my pan was all mos2. Redline is an ester and will clean old existing deposits so it's completely possible that the mud that drained out was old accumulation from the neglectful previous owner,however it's definitely possible that mud was mos2 settling out.
I'm not saying that mos2 settling out will cause any harm either,I wanted to post my observations so that if people are going to use it then they can find unbiased observations so that if they see something that concerns them they can easily find that someone gas posted about it already.
