Originally Posted By: Danh
Originally Posted By: C4Dave
Timing chain wear on GDI engines is caused by the high pressure mechanical pump being driven by cam gears or directly by the chain. Since the pump pressure is so high (several thousand psi), a much larger load is put on the chain. I don't think better oils or filters will help with the mechanical stretching of the chain.
So GM responded to premature timing chain wear in DI engines by reprogramming the IOLM to require more frequent oil changes because.....?
I don't know that is the case, but if it is my guess would be that oil is being diluted by gas and not lubricating properly. This would also happen to the very best oils and filters.
