This is the second sampling for my 2010 Subaru Forester with the N/A 2.5L engine. The oil was 5w-30 Mobil 1 (SN) + 1/2 bottle of MoS2, Fram Ultra filter, and Fram air filter. Miles on the oil was 9088 miles and 58999 miles on the Forester total. The Forester is driven by my wife and sees trips daily of 25 miles always getting up to temperature, no short trips. Driving is pretty easy but is 50/50 city/interstate with some rush hour traffic here is Portland, OR. The Forester has been a great SUV. I added the MoS2 just to see if there would be any change or improvement on fuel economy. I didn't notice anything increase in MPG so probably will not continue using it. But it didn't cause any issues. I cut open the Fram Ultra and there was no trace of the MoS2 in the filter (pictures posted recently).
The UOA looks good to me. I will extend out to 10k miles which will be just at 1 year OCI next time and resample. Oil was changed and again used M1 5w-30 and Fram Ultra.
Code:
DATE SAMPLED 19-Oct-14 20-Dec-13
Miles on OCI 9088 6100
Miles on unit 58999 49911
Make up oil: none none
Metals (ppm) (ppm)
Iron (Fe) 7 4
Chromium (Cr)
Lead (Pb)
Copper (Cu) 10 7
Tin (Sn)
Aluminium (Al) 8 3
Nickel (Ni)
Silver (Ag)
Titanium (Ti) 12 87
Vanadium (V)
Contaminants (ppm) (ppm)
Silicon (Si) 14 8
Sodium (Na) 8
Potassium (K)
Water (%)
Coolant No No
Additives (ppm)
Magnesium (Mg) 579 14
Calcium (Ca) 1187 2330
Barium (Ba)
Phosphorus (P) 661 702
Zinc (Zn) 769 799
Molybdenum (Mo) 170 35
Boron (B) 31 54
Physical Tests
Viscosity (cSt 100C) 10.1 9.4
Physical / Chemical
Base Number (mgKOH/g) 2.6 2.2
Here is what the lab said:
All wear rates are normal. Abrasive and other contaminant levels are acceptable. Viscosity within specified operating range.
This is ALS labs in Portland, OR. These are the NAPA UOA kits. The viscosity barely changed at all which is amazing. (from 10.4 to 10.1) I'm really happy with this run.
Code:
Metals (ppm) (ppm)
Iron (Fe) 7 4
Chromium (Cr)
Lead (Pb)
Copper (Cu) 10 7
Tin (Sn)
Aluminium (Al) 8 3
Nickel (Ni)
Silver (Ag)
Titanium (Ti) 12 87
Vanadium (V)
Silicon (Si) 14 8
Sodium (Na) 8
Potassium (K)
Water (%)
Coolant No No
Additives (ppm)
Barium (Ba)
Zinc (Zn) 769 799
Boron (B) 31 54
Physical Tests
Physical / Chemical
