Hello
I am new to this forum. I have a 2002 Honda Civic LX with 207k miles on the clock. I've had the car for 2 years and a few months, and I've put 30k on it since I bought it. It hasn't given me many problems until the last couple oil changes. It seems like I need to add more and more oil between changes. I've added over 1.5 quarts in about 1500 miles. I think my engine is burning oil because it smokes out the exhaust. It killed my catalytic converter and I had it replaced. It doesn't seem to have any other symptoms. The oil doesn't look milky, coolant level and color is ok. I'm not a mechanic but after doing some research it seems that it's my valve seals or piston rings. It runs fine no noise or other symptoms. So my question is would high mileage oil help and what else can I do to keep it going for as long as possible? I currently use Castrol GTX 5W 20. Should I switch to castrol high mileage and just drive it into the ground? Thanks.
