Castrol 0W30 vs 0W40
Originally Posted By: dparm
Originally Posted By: Bluestream
Thanks Guys, I am getting low on my stash of GC 0-W30 and I can buy the 0W40 cheaper in a 5 liter jug. I Thought the SL rated oils have more zinc, which is good for high RPM motors, I use this oil in my 1.8L VW, and my Sea-Doo and Ski-Doo 4 strokes...
Zinc is not necessarily better for high RPM motors. The benefits of ZDDP are greatly exaggerated, especially for modern engines. There are newer additives that offer the same or better performance.
Unless you are running some old-school flat tappet engine, I see no need for elevated ZDDP.
There's a TON of info on the BMW bike sites on zinc and flat tappet motors like the boxers BMW used to build.
It's probably just a matter of time before we see the updated graphics on the 0w-40 jugs as well...
And here it is...
Alas, we already knew it contains titanium, thanks to the VOA.
Originally Posted By: edyvw
GC 0W30 was the best all around oil for Euro application.
It had very, very good pour point, and it was almost 40 grade. Due to the weight, it was reaching temperature faster then 0W40 M1 or any other 40 oil. Also, I used it for years, and it was much quieter oil then M1, and had better cold start.
I think personally Castrol made mistake with 0W40 oil. They want to compete with established M1 0W40, instead of going with 5qt jugs of 0W30, to offer something different.
Also, one of the problem Castrol has are pds sheets. When I look at m1 sheet I know what I am buying. With little research you knew what you buying with 0W30 GC. Now no one knows what is HTHS of this 0W40 GC, what is pour point etc.
HTHS is on the Castrol USA site:
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4ABA633F17A143FD80257AA90053665B/$File/EDGE%20Professional%20European%20PDS_July_2012.pdf
It's not the actual HT/HS. It's just a minimum as required by ACEA spec.
Castrol 0W-40
Kinematic Viscosity 100C: 13.5
Kinematic Viscosity 40C: 79.3
HTHS viscosity: 3.7
CCS @ -35C:
Calcium % wt: 0.189
Phosphorous % wt: .099
Zinc % wt: 0.102
Flash point: 240C
Pour point: -54 or - 57C
Sulphated Ash: 1.12
TBN: 10.2
NOACK 9.1%
MRV @ -40C: 22,800 cP
Originally Posted By: vinu_neuro
Castrol 0W-40
HTHS viscosity: 3.7
CCS @ -35C:
Calcium % wt: 0.189
Zinc % wt: 0.102
Flash point: 240C
Sulphated Ash: 1.12
TBN: 10.2
NOACK 9.1%
I do not think that is Castrol we are getting int he U.S. or there is big difference of what Castrol claims and what actually is in the bottle:
Catrol 0W30&0W40
Like QP said, that is just required ACEA minimum.
