I'm going to edit this post so it is easier to see what I am responding to.
Originally Posted By: used_0il
..... Lets go back to our pickup truck with four tire options:
285/75/16
285/70/17
285/65/18
285/55/20
For simplicity all four tires are mounted on 9" wide rims, are E rated, of the same
brand, construction and have an od of 32.5"....
OK, first problem:
LT285/75/16 Load Range E - OD 32.8", Measuring rim 8.0", Max Load Single 3750# @ 80 psi (LR D = 3305# @ 65 psi)
LT285/70/17 Load Range E - OD 32.8", Measuring rim 8.5", Max Load Single (LR E doesn't exist, but LR D = 3195# @ 65 psi)
LT285/65/18 Load Range E - OD 32.6", Measuring rim 8.5", Max Load Single (LR E doesn't exist, but LR D = 3195# @ 65 psi)
LT285/55/20 Load Range E - OD 32.4", Measuring rim 9.0", Max Load Single (LR E doesn't exist, but LR D = 2835# @ 65 psi)
If we assume we have all Load D tires, the only one of the 4 that stands out as different is the last one. Let's not use that one. The others are close enough.
..... Which of the above four tires will provide the best fuel economy?...
I don't know of anyone that has cataloged what happens in that size range. The only study I know about is for smaller passenger car tires, and if I assume that single is anywhere near accurate:
The 17" is 3% better for RR, and the 18" is 7% better.
Keep in mind that a tread compound change would be many times those values, and that tires are a mere fraction of the total fuel consumption in the vehicle. For practical purposes, those differences in tire size are small enough to ignore.
..... If a second test is performed using the following two tires
also mounted on 9" wide rims:
265/70/18
265/60/20
Also 32.5" od, would the narrow 265 or wide 285 tires be more fuel efficient?....
OK, more problems:
The 18" only exists in P metric sizing.
But if I assume we are trying to test comparable LT tires:
Then the 20" is 7% better for RR than the 18", and 11% better than the LT285/75R16.
Again, because tires only contribute a fraction of the fuel consumption, even an 11% difference is small enough to ignore - on the order of 2% total FE change for the vehicle.
