Post your latest oil change
2006 liberty 3.7L
out: qsad 5w-30, Classic 20195 filter (no tears after cut open)
in: proline (warren) 5w-30, Classic 20195 filter
88 Ford f150 300 6cyl 160,000
unkown oil and oci. It had an OCOD on it for a filter.
In went 5 qts of Pennz syn blend 5w30 and 1 qt of pennz dino SAE 40.
Filter is a Motorcraft
2001 Tahoe - 1st change since purchasing it. 70k on it.
Out: Unknown oil, Parts Master filter. Roughly 3500 miles, if previous owner is to be believed.
In: PYB 5/30 and QS filter. Will probably run this combo until next spring, or roughly 4000 miles. Low mileage vehicle for me right now.
Does not consume any oil. Dipstick has always been precisely at the full mark. Did put a can of Lubro Moly in it, when I purchased it this June.
Couple weeks ago changed out the last of the 5w30 summer oil gotten on sale, and put in 4 1/2 quarts Amsoil 0w30 with an Amsoil filter. Good till next Fall at least.
2014 Honda Accord Sport
Mileage:3318
Out with the magical factory fill and factory oil filter
In with the 0W20 Mobil 1 AFE with an Ultra XG7317
2010 Nissan Sentra 73xxx miles
Out: Mobil 1 5w-30, Mobil 1 filter
In: Royal Purple SN 5w-30 3.5 qt., LSOS .5 qt., Royal Purple filter
2001 GMC Savana 1500, unknown mileage (replaced gauge cluster)
Out: Chevron 5w-30 and LSOS, Microguard (Wix) MGL 51036
In: Chevron 5w-30, 1/2 qt. Lucas Oil Stop Leak, 1/2 qt. LSOS, Microguard (Wix) MGL 51036
Winter oil change time.
2008 Ford Edge SEL AWD, 130,000 km
Out:
Castrol GTX High Mileage 5W-20
Mann Filter
In:
Quaker State Ultimate Durability 5W-20
FRAM Ultra
Did the air filter too.....swapped out FRAM Extraguard (replaced in kind)
1993 yota 4x4 22RE engine, Pennzoil PUP 10W30 + yota OEM filter. Will change oil again in 2 months with probably a couple hundred miles since I just replaced the timing chain, oil pump, water pump etc. Truck has 156K+ miles and friend said head, pistons and valves looked amazingly clean. I change oil every 5,000 miles with Mobil 1. I tried Amsoil a few times but went back to Mobil 1.
2013 F150, out: Amsoil SS 0w30, in with Amsoil SS 5w20. 30 weight experiment in the Coyote 5.0 completed....
2003 Liberty 225 - 5 quarts Amsoil ATM + EaO34 filter
1981 W150 318 - 6 quarts Amsoil ZRT + EaO15 filter
2001 Ram 360 - 5 quarts Amsoil ATM + EaO42 filter
2011 Prius - 95867 mi
Out: Toyota 0w20, Toyota filter, 6012 miles
In: Mobil 1 0w20, Toyota filter
I normally change at 10k, but I have not been driving as much recently and most of the driving has been comprised of short trips. The oil was pretty dirty and was 1/3 qt low, so I decided to change it early.
2002 Honda Accord 3.5L
Out: Valvoline bulk 5w-20 and Valvoline filter
In: QSGB 5w-20 and ProSelect filter
O/FCI was 3k Kms and 3 months.
'99 Legacy 2.2 AWD Wagon
Out: Meijer HM 10W-30, P1
In: 3 qts Maxlife 5W-30 + 1.5 qts Synpower 5W-30, P1
Oil was run from 4/17/14-10/27/14
Not that many miles, since younger son who drives this old dear is only buying ~20 gallons each month, which isn't a lot of miles in an old Subie. Back and forth to his work mostly.
2001 Honda Civic LX coupe
65xxx miles
Out: Quaker State 5w-20/Fram Tough Guard TG7317
In: Quaker State Ultimate Durability (3 qts. 5w-20, .5qt 0w-20)/Fram Extended Guard XG7317
The oil had somewhere between 5000-6000 miles on it.
