With flat tappet, definitely. With hydraulic and solid roller you can go much heavier.
Absolutely!!!!
However, always run the LEAST amount of pressure you can, based on the grinder's recommendations.
Also, have your springs TESTED at both closed and open heights, as we have seen springs incorrectly boxed, leading to disaster...
Absolutely!!!!
