Originally Posted By: bubbatime
Originally Posted By: lawnguy
Kawasaki FX 691V
That engine manual calls for a SAE40 weight oil in your Florida climate of above 68 degrees.
15W40 Delo or Rotella would be a good fit also. They are also a 40 weight at temp and have heavy duty additives that are better for wear.
If you absolutely must have a synthetic, then check out 5W40 Mobil Turbo Diesel Truck or 5W40 Rotella.
For those calling for SAE 40 and running in hot climates i would recommend Mobil 1 High Mileage 10w40.
Kawasaki FX 691V
