A ARB1977 Joined Jun 12, 2005 Messages 6,306 Location North Texas Oct 24, 2014 #1 How heavy are the fan in a home ac condenser? I need to straighten the fins that are bent. In order for me to remove the cage I need to remove the fan. Thanks
M michaelluscher Joined Oct 7, 2012 Messages 5,431 Location Staten Island, NY Oct 24, 2014 #2 Even if its a 5 ton unit, it'll be a bit unwieldy, but you should be able to lift it yourself. If you can't, a second person will make it easy.
