If you are seeing -30, the 0w-40 is the product you want in the pan. It is literally HALF as thick at that temperature as the 5w-40.
That's a new one on me; I didn't know that.
Yup, as per the halving rule, when you are down near CCS/MRV temperatures every 5C the viscosity is doubled/halved (depending on which direction you are going). I've seen a few PDS's that list CCS at multiple temperature and this generally holds true. So if you take the CCS value for a 0w-40 @ -35C, cut it in half and you have roughly the visc at -30C, to compare to a 5w-40.
So, we don't know the CCS for M1 0w-40, but we know it is below 6,200cP @ -35C. Let's say it is 6,000cP, at -30C it would be ~3,000cP. In comparison, Valvoline 5w-40 (MST or HST) is 5,900cP, essentially twice as thick. At -25C, the 0w-40 is ~1,500cP, while the 5w-40 is close to 3,000cP. Eventually the curves start to get closer to each other (as you approach 0) and then our next plot point is 40C where the 0w-40 is still thinner, but only by like 5cSt, and once we get to 100C, the 0w-40 and the HST are the same visc. The 0w-40 is actually thicker at 100C than the MST.
