WIX uses a different rating for CFM in their air filters. I don't know what it is or why?
Here is a old Hot Rod Magazine air filter test. Good reading for us gearheads, and note they are using 14"x 3" size. The CFM readings were measured air flow into the test engines. Enjoy!!!
Use the formula below to compute the minimum size filter required for your particular application. The usable portion of the filter is called the EFFECTIVE FILTERING AREA which is determined by multiplying the diameter of the filter times Pi (3.1416) times the height of the air filter in inches, then subtracting .75-inch. We subtract .75-inch to compensate for the rubber seals on each end of the element and the filter material near them since very little air flows through this area.
A = effective filtering area CID = cubic inch displacement RPM = revolutions per minute at maximum power
Example: A 350 CID Chevy engine with a horsepower peak at 5,500 rpm. If you are sizing a panel filter, multiply the width of the filter area (not the rubber seal) times its length. If you are sizing a round filter, use the following formula to determine the height of the filter.
A = effective filtering area H = height D = outside diameter of the filter 3.14 = pi 0.75 = the rubber end caps
Example: Referencing the K&N catalog shows the proper filter for this application would be an E-1500 which is 3.5 inches tall. Keep in mind, this is the minimum size requirement. To extend the service interval and to provide an even greater volume of air to the engine, install the largest filter that will fit in the space allotted. If the space above the engine is restrictive, perhaps a remote filter arrangement could be used to gain space.
Off-road conditions require added filter area. A filter should be sized 1-1/2 to 2 times larger than normal for any conditions that could be considered severe
Here's a dyno test done by hot rod on brands that I saved years ago. This was done in 2002
Air filter brand shootout
Hot rod
June 02
Test cars
Hot rods used 2 cars on each test, one car was tested on a chassis dyno the other engine was tested on an engine dyno
chassis dyno--- 1963 plymouth, 413 engine
engine dyno--- fresh pontiac 408, 8.8:1, 6x heads, custom comp cams hyd. flat tappet cam
The Results
Manufacturer: Advanced flow engineering
Description: AFE magnum flow 14x3 filter
Price: $59.56
Approximate airflow: 3,122 cfm
Chassis dyno: 251.1 hp @ 4,300; 307.9 lb-ft @ 4,250 rpm
Engine dyno: 365.9 hp @ 4,800; 444.8 lb-ft @ 3,900
Manufacturer: Holley
Description: Holley power shot 14x3 filter
Price: $39.99
Approximate airflow: 3,068
Chassis dyno: 250.6 hp @ 4,300; 308.7 lb-ft @ 4,250
Engine dyno: 367.2 hp @ 4,800; 444.6 lb-ft @ 3,900
Manufacturer: K&N engineering
Description: K&N filtercharger 14x3
Price: $69.93
Approximate airflow: 2,988
Chassis dyno: 249.7 hp @ 4,250; 308.6 lb-ft @ 4,250
Engine dyno: 368.7 hp @ 4,900; 444.5 lb-ft @ 3,900
Manufacturer: Purolator products
Description: Purolator 14x3 premium plus
Price: $5.99
Approximate airflow: 2,518
Chassis dyno: 246.7 hp @ 4,250; 305.6 lb-ft @ 4,250
Engine dyno: 368.7 hp @ 4,900; 443.5 lb-ft @ 3,900
Manufacturer: Barry Grant rush performance filters
Description: Rush 14x3
Price: $44.30
Approximate airflow: 2,836
Chassis dyno: 251.0 hp @ 4,250; 311.0 lb-ft @ 4,250
Engine dyno: 368.5 hp @ 4,700; 446.5 lb-ft @ 3,800
