1989 Chevy C2500 pickup, front discs, rear drums. Bled brake fluid recently, front pads good, have not opened rear drums so don't know. Normal braking is fine, usually everything works great. But occasionally when I've had to do rather quick hard braking I have found that there is not much stopping power at first and then I really stand on it and the brakes grab all of a sudden and stop the truck with a jerk. I can't tell if only the front or rear that are soft and then grab hard, or if it's all four at once, or what. Seems like it can happen when cold or hot so I don't think that is a factor.
Do I still have some air in the system? Is there a proportioning valve that is stuck somewhere? Is the master cylinder starting to go? Not sure where to look, any advice welcome, thanks!
