Originally Posted By: JasonTL
Today I drove it a bit and then parked it on flat terrain and cycled through the gears then shut it off and popped the hood. There was a wisp of smoke or something coming from the dipstick tube. I then pulled it, cleaned it, and put it back in and then quickly took it back out and it just barely read on the stick, so definitely low on fluid. The stick seemed to say add 1 pt(Pint), but shouldn't it actually be 1 qt(Quart)?
Anyone know offhand which fluid this vehicle takes?
Would low fluid actually prevent it from switching gears, or did the low fluid cause the 3-4 clutch pack to burn/fail?
The procedure for that vehicle is to check fluid with the engine idling and trans in park. (That might be stamped on the dipstick.)
If the fluid level is low with the engine off, it will probably be lower when idling because fluid is being pumped through the trans and converter.
If this was my vehicle, I would go to Wal Mart and buy a 99 cent transmission funnel and a quart of Dex-Merc, and get the fluid to the proper level. If that didn't fix it, then it would be time to start pricing transmissions.
The dipstick does measure in pints. It sounds like you can start with 1/2 quart, then check using the proper procedure and adjust the level from there. Note the marks for "Cold" and "Hot," too. If the fluid isn't hot from driving, it should be at the top of the cold range or just into the crosshatched area.
Good luck.
