dry rot = ozone cracking
Lots of good info on the wiki page: http://en.wikipedia.org/wiki/Ozone_cracking
Quote:
The problem can be prevented by adding antiozonants to the rubber before vulcanization. Ozone cracks were commonly seen in automobile tire sidewalls, but are now seen rarely thanks to the use of these additives. A common and low cost antiozonant is a wax which bleeds to the surface and forms a protective layer, but other specialist chemicals are also widely used.
I understand that tires in constant use bleed such wax to the surface forming contact protection. Tires not in use lose the protection due to wax on the surface destroyed by ozone (sacrificial protection).
You would think those antiozonant waxes should be commercially available for consumers to put back on the tire surface when tires are not in use.
Are they?
I also noted that some old timers put brake fluid or motor oil on tires and swear it prevents tire rot. Then a number of naysayers who never used it cry foul. Who is right?
I think we can agree that solvents on tire is a bad idea as they wash away the wax and increase ozone production when exposed to UV light.
Are they?
