Originally Posted By: willbur
So moly is OK for wheel bearings now? Lots of discussion here indicated it was harmful for wheel bearings. That it was abrasive and ment for sliding surfacess only, or that it was too slippery. So...which is it?
I think the issue was if it had to much moly, not the moly itself. I am guessing ford wanted a 1 size fits all grease so they added enough moly to work as a decent chassis grease but not so much it would damage or impair wheel bearings. Valvoline synpower grease has a little moly in it and many use that on wheel bearings, as have I, without issue.
I use different greases for wheel bearings than chassis now as I wanted a better chassis grease. My grease gun right now has Jet-Lube 202 grease while my bearing packer has some clearance Castrol syntec grease in it.
