Picked up a used poulan "wild thing" leaf blower on the cheap because it stopped running. PO thinks its a carb issue. Well I stripped it down and everything looked good except a cracked bulb primer; replaced the primer, fuel lines and fuel pick up as well as the spark plug (gapped!) and cleaning the carb out. Carb looked good and gaskets were in good shape, even the diaphragm had no pin holes visible. It gets spark. It won't start.
Primer will prime, and excessive starting attempts results in fuel coming out the intake. Plug appears to show spark when tested. Ideas? I did order a carb kit as I figure maybe its something you can't see with the naked eye, but otherwise I'm stumped.
