Originally Posted By: HerrStig
Originally Posted By: CapriRacer
Originally Posted By: Camprunner
Do tires that are thinner or less wide do better in the rain? Givin the same exact tire and tread pattern let's say one tire is a 245/75/16 and one is a 285/75/16 will the less wide tire have better wet traction?
OK, you've got more than just one parameter in your example. In engineering terms, you've confounded the question. Your example also includes load carrying capacity as a parameter - unless you adjust the inflation pressure, then you've added THAT as a parameter.
A better comparison would be 2 tires of the same make and model with the same load carrying capacity, but different sizes. Like a 205/75R15 and a 215/70R15.
So let's use those 2 sizes and answer your question:
First, you have to understand that wet traction consists of 2 things: Hydroplaning resistance (which is highly speed dependent), and the - oh, I'll call it "grip". To get the amount of traction available, you subtract the amount hydroplaning from the grip.
As a general rule, wider is worse for hydroplaning resistance. However, grip is dependent of the amount of contact - so wider is better.
So it very much depends on speed.
Returning to your example - too many variables. If we assume the load carrying capacity is adjusted to be the same by adjusting the inflation pressure, then we have a situation where the contact patch shape has changed, the size of the contact patch is more or less the same, so the net effect is the same as my example above, but this answer isn't nearly as true.
I seem to recall a physics lesson which demonstrates that friction is INDEPENDENT of the area of contact, but rubber does not behave the way a couple of steel cubes rubbed together does.
That's static friction.
http://hyperphysics.phy-astr.gsu.edu/hbase/frict2.html
