Rotate warm or cool?
Nope, just have to set the tire pressures correctly if they are staggered. Should be nice with everything cool like brakes and such...
Hello, You're probably out there now rotating.
My suggestion is to take the time to inspect both sides and the entire tread of each tire.
It's the forgotten benefit of rotation.
Also, make sure your spare is good and flat. Kira
Originally Posted By: berniedd
Am I missing something here? A spare tire that's FLAT?
I think he meant full of air. You would be amazed how many people are driving around with flat spare tires.
Only disadvantage would be that everything is kinda cool. As fall temps are on us, and winter not far behind, it might be nicer to get things warmed up a bit.
Only advantage would be that you're able to get a more accurate PSI on a cold tire. Besides that there is no real advantage.
