Question about an interference diesel engine.
If the timing belt is removed, would the engine still be able to rotated or will it stop when pistons contact the valves?
When a timing belt breaks, engine goes a few more revolutions to chew up the valves, would it be easier to rotate the engine without camshaft turning?
I ask because I looked at an Isuzu I-mark diesel fastback w/ auto trans. 0 compression in #1. I rotated the crankshaft a few times and there was no resistance. Turned the camshaft a few times, still no resistance but noticed the cam sprocket would move a bit once while rotating crank.
Sounds like its blown. Since it's an auto, the engine would have stopped quicker than if its a manual, = less damage?
Thanks for your feedback.
Mike
Mike
