Originally Posted By: gathermewool
Originally Posted By: Olas
If she can't match the colours red to red and black to black she probably shouldn't be driving.. What if she gets confused by a red brake light or stop light and thinks it means go?
IQ tests should form part of the driving test..
You should probably re-read the thread... He instructed his wife where to hook up and she apparently did so without issue, so what's your point?
OP, I'll be curious to hear how the LED lights work out for you. I'd like to get some LED's, but really can't find fault with the OEM lights. Considering I've had older cars with original bulbs, it's hard to justify an LED swap for cost savings reason, regardless of what the purported life of the LED's will be - I simply don't believe they'll last their claimed life (nothing to back that up.)
I would like to add a bit more light to the cargo area and cabin, though, and some red map lights might help minimize night-time blindness when they're occasionally used while driving by the passenger. I'm worried that the red map lights will simply look cheesy and not perform as intended (i.e., they'd be more form than function.)
Well - I wouldn't say without issue. I had to explain and reexplain things several times. Also - the charger wasn't automatic since the user has to select both the type of battery and the charging rate before it will start charging. I had a 1.5A maintainer that would have been simpler, but I don't think it was fast enough to get it to start in a half hour.
As far as the light goes, I ordered "natural white" DE3175 equivalents from superbrightleds.com. The orientation seems to be important since they have a relatively limited angle where it's really bright. The color is really white, as compared to the OEM Toshiba bulbs that look yellowish. I could have ordered the "warm white" (slightly yellow) version, although I'm not sure how yellow they would look. They seem a bit brighter than the factory bulbs. When I checked the factory bulbs, they were getting hot. These LEDs were cool to the touch. I heard that contact orientation might be an issue, but there was nothing on the bulbs that said which side was positive. I tried it both ways and it worked either way, so the designer did something to make the contact orientation unimportant.
So here's hoping that these things keep my wife from killing the battery again. I've got them on both map lights and the dome light. They're all the same DE3175 mount. When I got a replacement the last time one burned out, I spent a bunch at the dealer since the cheaper Sylvania version only came in 10W.
