Originally Posted By: 20pss
I will say that I have ran 50/50 of parts store brand coolant my whole life, and never had a problem. Last winter it made me consider if I was doing enough. Here in Minnesota, temps got below -30F a few times by me, and parts of the state went below -40F. I never had a problem, but I heard of numerous reports of cracked radiators, overheating, or other problems. Damaged heater cores seemed to be a big one.
While keeping your cooling system well maintained, with coolant/antifreeze that is fresh and of the proper concentration, is very important, many of the problems you mention can also be avoided by allowing an engine to get up to temperature before driving.
Over 30 years ago I remember working in the cold of winter, at a plant that was in the Western Utah desert. When we got off work on graveyard or swing shift, it would sometimes be in the below 0° F temperatures. And it was so odd to be driving home, and see a co-worker pulled off the side of the road with an overheated engine. At that young age, I didn't understand how a car could overheat in the dead of winter.
My carpool friends explained that in conditions that cold, it is very important to allow the engine to warm up to where the thermostat opens before driving, particularly at highway speeds. If you drive before the engine warms up, the cold air passing through the radiator can turn the antifreeze, that is currently standing still in the radiator, to turn to a slush, or even almost ice. Once the radiator does open up, the ice blocks the circulation and the engine overheats.
If you wait until the thermostat opens, before driving, then the coolant is flowing through the radiator, and is is warm enough that the cold air will not freeze up the radiator.
Keeping a car in a garage, or using a block heater, all help greatly. But we can't always do that. There are times where our car may sit at work, or at an airport, etc, where there are no garages or access to plug in a block heater. At those times, it is good to remember to properly warm up a car before driving in winter months.
