Originally Posted By: ecotourist
Originally Posted By: UG_Passat
190,000 miles and will be doing the second intake cleaning soon, on a VW 2.0T FSI.
The IS250 only gets Toyota D4 engine, which is direct only. The IS350 (and the GS, LS, LX & GX) gets Toyota's D4-S system, which gets port injection also, so you won't see the same issues, unless you use poor quality gas.
Thanks for responding. That's pretty good miles.
Have you tried using a catch can? It seems like a good idea. Do you drive on the highway or in city? Hard or Easy on the accelerator? Ever tried a seafoam injection through a vacuum hose? What oil do you use? A low NOAK oil should make a difference.
I was aware of the difference between the IS250 and the IS350. A shame they didn't give the IS250 the same treatment.
Ecotourist
Catch can? no, it really doesn't make much of a difference.
Normal driving habits? I'm usually easy on the accelerator.
Seafoam? Doesn't work, unless you do it every 5000 miles. .... but run the engine at 4000+ rpms for about 20-30 minutes on the highway, about every 5000 miles.
Oil? Shell Rotella T6 or Chevron Delo 400 LE, whichever is cheaper.
