I have a Bosch double oven which has started to act up.
Firstly, the top oven, which is used the most, decided to come on by itself after it was used and turned off. After turn off, it spent several minutes (as is normal) running the fan to expel heat, but after that, it started up again.
So I turned it off at the breaker and decided to only use the lower oven, which has hardly been used.
Today, the light for "Heat" on the lower oven stayed on / went on, after it was turned off and after it had cooled. It is lightly flickering. It goes off if the timer control knob is turned to Lower Oven (it is usually on "Both Manual"). In all other positions, the "Heat" light flickers.
Since both ovens are afflicted, it would seem to be a control board issue. But just wanted to get thoughts and opinions on what other tests I should do before I start throwing parts at it.
