Originally Posted By: dparm
To be clear, OP, does Nissan REQUIRE that oil, or is it simply recommended? The wording is very important.
When they came out with the new DLC coated valve train, it could be a bit noisy. Nissans response: check out this great oil which will quiet the valve train.
At 10+ a qt, we even recommend it! Many nissan dealers are not really that aware of it and quarts are dusty in the parts department. My local dealer never even tried to recommend it, instead a normal $30 oil change (I simply give them my own oil, pay for filter/labor).
In the US, any 5/30 certified oil is allowed, strait from the manual. Wider ranges are allowed in non-US areas, also strait from the manual.
I use PU 5/30 and have posted my UOA trending in the other forum. May go to M1 0/40 once warranty is over. We shall see.
- b
- b
